Good cam for drag racing ls1
Old 09-02-2010, 05:36 PM
89z28's Avatar
Default Good cam for drag racing ls1
im looking to put a cam and a set of roller rockers on my ls1 but do not want to spend alot of money any suggestions?
g
Old 09-02-2010, 05:53 PM
projectX's Avatar
Mods?? Current set up?
Old 09-02-2010, 05:57 PM
KevinR's Avatar
How much do you have to spend? You can't just change the cam. You are looking at valve springs, pushrods, timing chain (not necessary, but a damn good idea) maybe the oil pump..So it isn't going to be cheap. Also, what other mods do you currently have? M6 or A4?
Old 09-02-2010, 05:58 PM
KevinR's Avatar
Oh, you will need to look at getting a tune as well.
Old 09-02-2010, 06:45 PM
89z28's Avatar
it is a stock ls1 as far as i know and is coing to have a carb not injected if that helps, dont have a lot of money because the whole car is being done and i dont know anything about ls1 motors but got a good deal on the motor
Old 09-03-2010, 01:31 AM
gnx7's Avatar
Save the $ and rebuild your stock rockers with the Comp Cams trunion rebuild kit. They work just fine. Pick up a used cam in the for sale section. You will need upgraded pushrods and double valvesprings. The stock ls1 intake with ported tb does a good job on a budget. Mill the heads for more compression. Check P to V clearance if you do. Racing isn't cheap!
Quick Reply: Good cam for drag racing ls1
