LT1 Custom Build ??'s Computer.....what to do??
I Am Building a 95 Trans am. Car Already has Shorty headers Exhaust KN CAI, extreme energy cam, stock heads, 6 spd, Stock Rear, 58mm TB, Now I Am going to bump up the Compression Forged pistons, pink rods, And a 150 shot. what will i need to do to the computer??
what are optoins for Computer software??
Ion(madz28) @ www.madtuner.com
Ed Wright @ http://www.fastchip.com/
Solomon @ http://www.lt1pcmtuning.com/
and pcm4less
Those are the big LT1 tuners, I suggest doing some research on them before just picking one, theres not much negative stuff said about MOST of them however I have seen allot of negative comments/bad results from one of those tuners..
and pcm4less
Yeah I will definitely look into them.
I don't. See this being a train wreck. Other then the rear end might break. But forged pistons good rods balanced and tuned right......what could go wrong ha
Combination of weak stock parts and mismatched performance parts. Set a goal of exactly want you want to do. research proven combos and talk to engine builders. If you have a HP goal in mind then you know what you need to buy instead of slapping parts on. Ex. Stock rear end is garbage and a 58MM TB is way to big for anything listed in your build.
