ETP 245 Rocker Arms
ETP 245 Rocker Arms
I'm purchasing a set of ETP 245 heads but I'm a little concerned about not being able to locate the correct rocker arms for my setup. The seller is including the rocker arm stands that come with the heads (the black bars). So which rockers work and is anyone still selling them?
I've got LS1 T&D shaft mounts on the shelf but will the valve spacing be correct. I plan on running an aggressive cam in a high boost 408 application so valve float is a concern. The seller offered to sell his hardland sharp rockers that worked for him but I think there to heavy. Any suggestions on the valvetrain options for the old ETP 245 heads?
Thanks
Thanks
