ASA LS1 won't run once car at operating temp
Old 09-14-2010, 10:14 AM
Bahnstormer's Avatar
Default ASA LS1 won't run once car at operating temp
Ok heres the deal - I am road racing one of the ex-ASA touring cars that has the Lingenfelter prepped LS1. The car uses the standard GM type ECM. The car runs fine until it reaches around 180 degrees at which point it begins cutting out and smoking like a freight train. If I let the car sit for 2-hours and fire it up all is good again. Anyone else encountered this?
Old 09-14-2010, 10:25 AM
mike mlodecki's Avatar
did you ever get it tuned before? i had an issue like that when it got to operation temp. the tune was messed up.
Old 09-14-2010, 10:30 AM
Yes, I have had three different tunes on two different ECU's - two done by Schwanke and one done by LG. LG actually had it on there dyno and the numbers looked good, but once on the track a different story.
Old 09-15-2010, 08:06 AM
Old Geezer's Avatar
Scan it and make some data logs....
Sounds like it's going nutz when it goes closed loop????
Old 09-15-2010, 08:12 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
They don't go to closed loop.
So does it do it with all three boxes? If so, it is something in the car.
Are you turning the fans on at that time? Maybe your alternator is getting weak and with the extra load it is going to low voltage wich would make it run wierd?
Is your fuel pressure steady? How about oil pressure?
Old 09-15-2010, 08:43 AM
im guessing fuel pressure
Old 09-15-2010, 09:20 AM
Torque_SS's Avatar
i would agree do some data logging to help you troubleshoot or at least monitor what is going on
Old 09-15-2010, 10:08 AM
Ok, these ideas giving me a starting point - thanks for the help
Old 09-15-2010, 10:19 AM
In response to Schwanke - no matter which box I install it is the same result. If the car sits and cools down I can restart it and it runs fine. Oil pressure and fuel pressure are good. I hadn't thought about the voltage but the car always starts right up even when its running bad.
Old 09-15-2010, 10:29 AM
incbed's Avatar
you didn't say what color smoke??
But I have seen engines with blown head gasket that doesn't start leaking into the cylinders until the engine is up to full temp when the thermostat opens up.
Just a thought.
Quick Reply: ASA LS1 won't run once car at operating temp
