lots of parts wanted for 4th Gen f-Body (98 Trans Am)
12 bolt rear end preferably with with 3.73 - 4.56 ring & pinion gears
Tranny cooler (preferably B&M 70264) but open to others at least 14K BTU
set of Koni SA, Bilstein HD or Bilstein SLP valved shocks
front sway bar - Strano's preferably
rear sway bar - preferably 19mm solid, a 21mm solid or a 22mm hollow bar
Panhard bar (preferably aluminum double adjustable rod end)
Lower Control Arms (preferably - Spohn, UMI, Strano Sports, Specialty Products) - let me know what type you have
Aluminum Flywheel
brake kit / upgrade kit (to replace stock) that will fit under 18" wheels
sub woofer speaker box (preferably stealth box but open to monster size ones that fit dual 12's etc.)
Subframe connectors (3 point weld on preffered but open to options)
saved the best for last;
a gently used or rebuilt Procharger/Vortech S/C or STS Turbo system (complete & working with no issues preferably)
open to other parts (especially anything custom fabricated) for 4th gen F-Body / 98 Trans AM - let me know what you have.
Please PM me what you have & price along with pics if you have them
Thanks,
Tom
Ellenton, FL
(Manatee County)
941-227-4154
Aluminum Flywheel
Thanks,
Tom
Ellenton, FL
(Manatee County)
941-227-4154
I have Lower control arms race style in red and i have a full procharger kit complete with the programmer P-1SC, the kit has 6k on it 7 psi kit twin intercooled.
The LCA's are slightly used i am wanting $170
and the procharger kit $4000
Lmk if interested send me a PM
any interest in those parts i listed? i also got American racing headers LT's with y-pipe.
a level 4 FLT transmission.
Torque thrust 2"s with Nitto extremes.
BMR torque arm.
BMR lower control arms.
BMR torque arm.
