stripped bolts on rear cover
Old 09-18-2010, 02:11 AM
spdrcr7882's Avatar
Default stripped bolts on rear cover
i was reinstalling my oil pan and stripped the bolt holes that go up into the rear main cover. I have a 5.3L iron block, and i didn't reaize that the rear cover was a weaker metal, (I assume aluminum). I have the engine back apart, becuase i am replacing the bearings. What would be the best solution to the striped bolt holes. Buying a new rear cover, or retapping the holes? Any advice is greatly appreciated.
justin
Old 09-18-2010, 04:23 AM
01ssreda4's Avatar
Buy a new/used cover. IMO trying to save the threads by retapping the same size is a lose/lose. You can find covers cheap here or on ebay.
Old 09-18-2010, 08:51 AM
Pocket's Avatar
You can helicoil them, but a new cover is less than the helicoil kit. Dont torque the next one so tight
Old 09-18-2010, 10:41 PM
spdrcr7882's Avatar
Ya, will def be following the tourque specs on the next cover. Would anyone happen to know if the rear cover is the same from a 5.3L block to a 5.7L. I assumed they were, but when I looked on ebay the covers that were for the 5.3, listed other engines they would work with, and the 5.7 wasnt one of them. just wanted to make sure before I bought a cover and it didn't fit.
Thanks
Justin
Old 09-19-2010, 12:22 AM
Pocket's Avatar
All LSx rear covers interchange. Only the LSX block requires a specific cover
Quick Reply: stripped bolts on rear cover
