c5 Y2K thinspokes... not sure on offset and if they'll fit no prob
well i bought Y2K thinspokes..
if i measured right, they are
9.5" rim (from inner lip to inner lip)
17" diameter
i read the sticky and saw i could have up to a 56mm offset..
so, i tried measuring the offset and it seemed to be 54mm or 56mm
it was hard to get an accurate reading with rulers etc
i plan on putting 275 40 17s on them all around.. so this wont rub in the front or the back right?
because the stock SS's came with 275 40 17 ??
my car is lowered about an inch because of koni/strano suspension setup also..
so if any of you with the same suspension setup and same size rims could chime in, itd be great assurance before i spend $600+ on tires etc
thanks
17" diameter
thanks
