coil pack, harness, brakes, just to start...
Ok progress has begun, but i need some parts.
one coil pack for an ls1. BOUGHT.
a computer and wiring harness for a 99-02 fbody, ls1/4l60e.
Complete brake setup from a 98-02 fbody, front brakes, rear brakes and ALL hardware EVERYTHING. PENDING
Let me know what youve got and what it would take to get the parts to 29483.
The most important peices i need are the front calipers (complete with pads), flex lines, bolts, rotors. The rears i need calipers (complete with pads), flex lines, backing plates, ebrake assembly, bolts, and rotors.
Im swapping ls1 brakes on to an 86 monte carlo.
Ive got a set of Corvette C5 Z06 brakes mounted on LS1 spindles with billet caliper adapters. Come with rotors, pads, calipers, caliper brackets, hubs, & spindles. Its already all put together even. Its a more expensive setup than LS1 brakes, not sure what you budget is but ill take $500 for the setup...
