th400/csr shield-help needed
after fighting with the driver side bolt issue then i run into a shift cable battle. when you go to route the cable around it will have to much bend between the shield and the tunnel. can anyone give some advice to this problem. im going from m6 to th400 and the shifter is a b&m stealth pro ratchet.
thanks
thanks
it feels wierd pushing into park all other gears seem to be good for now until i start the car and check it then. it feels hard to shift, the aluminum that i mounted to proly just needs more support. just giving a little update so if anyone searches csr shields like i did and couldnt find anything
