how is this product?
Old 09-20-2010, 07:06 PM
TheTransporter69's Avatar
Default how is this product?
http://www.summitracing.com/parts/NAL-10115875/
Hi, im looking to buy the ac delete pulley, i hear some don't line up, some squeak and make noise, and some need a shorter belt. Just wondering if this has those problems or if this one fits like it should.
Old 09-20-2010, 08:51 PM
SoxXpupPeT's Avatar
abit expensive. i sent you a pm
Old 09-20-2010, 09:06 PM
robsquikz28's Avatar
hit up pepboys they have them in stock and will fit with the stock belt
Old 09-20-2010, 09:24 PM
tscheu5452's Avatar
If I had to do it over again, I would get that one. I bought a Dorman that is sold at Advance and a few other places and had to use six washers (two per hole) to shim it out correctly. I haven't heard anything negative about the GM piece yet.
Old 09-20-2010, 09:31 PM
Slowmaro95Z28's Avatar
I bought the same one today only because it was in stock at Advance. I also used 6 washers to shim it. I used some pretty thick washers and I still may need one more per bolt. I am using my stock length belt though. Everyone says the GM piece is direct fit with no shimming at all. I'm not sure if it takes a shorter belt.
Old 09-20-2010, 10:32 PM
shbox's Avatar
The different belt thing is a product of what a/c pulley was originally on the car. There were two diameters of a/c pulleys used over the years. I believe the delete pulley comes in one size. So, there is a chance you might have to change the belt slightly. It's not a huge deal.
Old 09-21-2010, 10:50 AM
thanks for the info everyone
Quick Reply: how is this product?
