F body accessories on 6.0L Iron Block
How many of you are running F-body accessories on your 6.0L 4th gen swap?
I want to see how it's set up right. I've heard you can run the F-body accessories on the LQ4/9 but that there is a certain bracket hole you need to drill somewhere, does anyone know about this?
The following users liked this post:
jetfixrguy (05-08-2023)
1 hole already in the block... 2nd hole has to be drilled...
3rd hole doesnt have a boss to drill into..
rear bracket hole is on the side of the block - I dont use the rear bracket because I have a 145amp truck alternator
I highlighted the picture to show where the bracket holes line up for the LS1 Alternator bracket
