Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Z06 converting to auto??
Old 10-04-2010, 07:35 PM
Ego Killer's Avatar
Default Z06 converting to auto??
I have a 03Z what all is involved in converting it to an auto?
Old 10-04-2010, 09:47 PM
SCM_Crash's Avatar
There's already a thread on this... But there's a lot involved.
It requires dropping the torque tube, replacing the trans, needs a flex-plate and converter, I believe there's a different drive shaft. You'll need to change the peddle assembly, and shifter assembly. You'll need a different tune that tells the computer you have an auto. I'm sure there's other things I'm forgetting right now, but in general people pay about $7K for a shop to do the conversion I believe.
Old 10-04-2010, 09:56 PM
Ego Killer's Avatar
I would do the work myself. I knew the pedals, tune, trans obviously. mainly I ment weather it needed a different wiring harness and the Torque tube and such
Thanks, Jason
Old 10-06-2010, 11:55 AM
Bankz27's Avatar
I am sure people would suggest this but would be easier of getting a C5 Platform i do believe..
Old 10-07-2010, 01:41 AM
beavis's Avatar
Thanks, Jason
Yes, it requires a different wiring harness and an adapting harness from RPM to use it along with a new torque tube.
Old 10-07-2010, 05:12 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
RPM Transmissions has a lot of experience in this conversion, give them a call.
1-800-406-1109 or 1-765-378-0625 Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 10-11-2010, 01:13 PM
BlownVette 2001's Avatar
Thanks, Jason
I've gone both ways. I don't know what kind of power you plan on putting down, so depending on that can change the price and configurations.
Basically you need.
Pedal Assy
Bell Housing
Flex Plate & Spline Lock
Torque Tube
Shifter & Ignition and tranny shifter cables
Adapter Plate (between Transmission & Differential)
Transmission
Torque Converter of your choice
Tranny Harness from an automatic of similar year
Engine / PCM Harness for Tranny from RPM.
You'll need to re-pin some of the PCM wires and add new harness to control transmission. Mechanically speaking it's not to much different from changing out a clutch.
Most of the work is in the wiring and reflashing of the PCM.
Quick Reply: Z06 converting to auto??
