Installed new t top headliner, removed dome light..need fix
Old 10-04-2010, 08:29 PM
mrrman's Avatar
Default Installed new t top headliner, removed dome light..need fix
I gutted my car and redid everything, installed a new t top headliner but never installed a dome light. I used the existing wiring for my powered rear view mirror. After installing the visors and seatbelts, there is a sag in the middle since the dome light took up the slack. What can I put in its place to keep the headliner tight and in its place? Do they make LED battery powered dome lights that I can attach to the roof? Any suggestions?
Thanks
Old 10-05-2010, 12:05 PM
1SLwLS1's Avatar
There should be holes in the roof structure for push retainers. I know that my headliner has one for the actual middle of the headliner, between the t-tops, and one that would be covered by the dome light. You can pick them up from the parts store for cheap, just look in the Help! section.
Old 10-05-2010, 04:24 PM
mrrman's Avatar
Where is the HELP section??
Thanks
Old 10-05-2010, 04:25 PM
1SLwLS1's Avatar
At your local parts store. It is a brand...
Quick Reply: Installed new t top headliner, removed dome light..need fix
