Need help with ewp install how to remove drive gear
ok got every thing tore down and the hole in the timing chain cover welded up. I cant figure out how the drive assembly comes out. I removed the 2 bolts securing the plate and lossend the timing chain its self but i cant get the drive to move more than 1/8 any suggestions???
well for starters the cam gear is in the way. once you remve it then you can press or knock the back side of the wp gear out of place. it will be in there good and tight, you may need to remove the intake if it wont come out to gain access to the rear
