comp ratio, ran a calc?
Old 10-10-2010, 01:29 PM
slomarao's Avatar
Default comp ratio, ran a calc?
I have been getting everthing figured out for my build and have been real busy with work. I ran my numbers into a comprssion calc and came out with 12.2.1?
I have a stock spec 357 build (40 over bore, 3.48 stock crank). The crank has been turned .020, .027 headgasket, .014 milled off the heads (94 casting) no decking or anything done to the block aside the .040 bore. The piston is just as far in the hole as stock.
I thought i would be around 11.6.1 or 11.7.1? any help
Old 10-10-2010, 01:41 PM
gregrob's Avatar
What piston relief...
Old 10-10-2010, 01:52 PM
kgkern01's Avatar
Assuming about 5cc volume piston reliefs, stock deck height is usually around .025", you need to know your head cc's. I assume around 53cc being milled .014". You also need to know the bore size on the head gaskets, what gaskets are .027" thick? I know the Impala gaskets are .029" and 4.1" bore and the 1074 Felpro's are .026" thick with 4.125" bore.
So using the folowing:
'assumed' 5.0 cc valve relief volume for pistons
.027" thick, 4.1" bore head gasket
3.48" stroke
.025" deck height
53cc chamber volume
I get an 11.58:1 SCR
Old 10-10-2010, 01:56 PM
gregrob's Avatar
3.48" stroke
.025" deck height
53cc chamber volume
I get an 11.65:1 SCR
I always use .034 deck height. Seen a bunch of people say that's where theirs measured. Did you use a 4.060 bore in your calculations?
Old 10-10-2010, 01:57 PM
speed_demon24's Avatar
Uh....
Old 10-10-2010, 02:02 PM
slomarao's Avatar
the custom gaskets are 60 over so they dont go into the chamber
Old 10-10-2010, 02:07 PM
gregrob's Avatar
Uhhh yeah. Whats your point
Old 10-10-2010, 02:09 PM
slomarao's Avatar
I answered the question, whats your point?
Old 10-10-2010, 03:21 PM
RamAir95TA's Avatar
LT1 gasket bore sizes are usually 4.100 or 4.125. You shouldn't need a "custom gasket" to prevent them from entering the chamber. Are we all talking about the same thing here?
Old 10-10-2010, 10:01 PM
slomarao's Avatar
I was on the phone with a summit racing tech, he said this is the way to go for my setup
Old 10-10-2010, 11:25 PM
gregrob's Avatar
Lol..
Old 10-11-2010, 06:48 AM
RamAir95TA's Avatar
Oh boy. Have you tried consulting an engine builder, and not a part-time parts guy at an internet wholesaler?
Old 10-11-2010, 01:11 PM
slomarao's Avatar
thanks for your help guys, really, glad i posted the question
Old 10-11-2010, 01:34 PM
RamAir95TA's Avatar
We're just trying to clarify what you've got going on that's all. Summit techs don't exactly have the best track record for providing accurate and relevant info in a performance build.
Old 10-11-2010, 02:51 PM
Puck's Avatar
Your CR will be ~11.4-11.5.
Old 10-11-2010, 08:43 PM
slomarao's Avatar
THANKS, that is all i was looking for.
Old 10-11-2010, 08:57 PM
Mine was .015 or .020 i think. It's been awhile but I came up with 11.4-11.5 with a .029 gasket and 53cc chambers.
Old 10-11-2010, 10:15 PM
slomarao's Avatar
close enough, Ill call it 11.6.1 cuz i have a 027 gasket
Old 10-12-2010, 04:27 AM
RamAir95TA's Avatar
Agreed...I've seen anywhere from .015" (mine was .020") to .030" on a friend's car (highest I ever saw was .030").
Quick Reply: comp ratio, ran a calc?
