Can Somebody gimme some insight on my tune?
Old 10-10-2010, 07:16 PM
LS88FoxBody's Avatar
Default Can Somebody gimme some insight on my tune?
I have a 91 Mustang with a 03 5.3 ....
Motor is Cam , And converter ,and Intake .
Heres 2 logs...
File Type: hpl
File Type: hpl
File Type: hpt
Old 10-10-2010, 07:26 PM
rskrause's Avatar
Heres 2 logs...
You should post what the issue(s) you are trying to solve are and some details of your combo.
Richard
Old 10-10-2010, 07:51 PM
Well It seems to lean out . Fuel Pressure is 60psi .
Car is 91 Mustang
Kooks 1 7/8 Hedders , Stock Heads
Comp Cam 224/230-.581/.588
54-444-11
These Xtreme XE-R camshafts from COMP Cams are made for all-out racing. The aggressive lobe design of these cams can handle all the rpm you can throw at it. So go ahead, take it to the Xtreme! COMP Cams has you covered.
:Specifics:
# Basic Operating RPM Range: 2,000-7,000
# Duration at 050 inch Lift: 224 int./230 exh.
# Valve Lift with Factory Rocker Arm Ratio: 0.581 int./0.588 exh. lift
# Lobe Separation (degrees): 114
# Grind Number: LS1 XER273HR-14
Comp Pushrods ,and valve springs.
ARP Rod Bolts ,and Head bolts .
Fast 90 Intake , Edelbrock 90mm Throttle Body.
3" Dual Exhaust X Pipe ,and Thrush Welded 3" Mufflers.
A1000 Fuel Pump 10 Gallon Fuel Cell.
Aeromotive Filter before ,and after Pump , -10 Feed , and -10 to Y block. -8 At w block to back of rails , Aeromotive Rails With Stock LS1 Injectors. -8 From Front of rails to regulator. -8 From Regulator to Return to the cell.
At times motor runs great but most times it seem very lean ,and from a stop outta the holes its gutless. Oh 3400 Stall , and TH350 with manual valve body and brake , and a 3.73 Gear on 28ET street.
Old 10-11-2010, 05:07 AM
rskrause's Avatar
I am no LS tuning expert, so I hope someone who is can chime in. Do you have a wideband? It it really lean? Is it only out of the hole that it lacks power? Where does the converter flash to?
Rich
Old 10-11-2010, 09:21 AM
If you watch the log , you can see the AFR reading off the wideband. Yes it really leans out... And off the brake the converter flash's at 3400 . Exactly where it's supposed to. But the car is gutless trying to launch it off the brake.
