times for the new 355 with 21* heads
Went to the local 1/8 milw track.. This is the 1st time out with the new motor. She went 7.43@97 with 1.60 60ft.. The track prep was crap and couldnt hook up all day.. I think at a better track she will go 7.2s
That thing should really scream in the 1/4. for what your 60ft is its really picking up huge on the bigend of the track. your mph is crazy, especially considering the DA.
My car runs 7.30@93.5 on a 1.6-1.63 60ft with 2000-2500DA. Id like do see what it will do in the 1/4.
thanks guys. Still got some bugs to work out on it.. Im wantin high 1.4 to low 1.5 60fts. gona take little more wieght out and try it again friday nite at a better track
That is great makes me happy I bought into the 21* heads, you think the ported intake picked it up any over your stock intake? Also did you see the results from ported to epoxy/ported intake that Stealthformula ran after the manifold swap?
The car should have run 11.50's-11.60's in the 1/4mile, on a 7.43 1/8th mile pass b/c a few years back when I had LE1heads/cam setup my car ran consistant 7.30's-7.40's on motor and ran consistant 11.50's. I was only running 3.42 gears and the car was a little heavier. Goodluck Later
Thats awesome every little bit helps and your car is running hard for whats in it. 97MPH in the 1/8th is unreal for out of the box heads, Im just going to touch up my 21's ditch my vic jr and port a super vic to match them. I have been waiting for your track times since I want to build a mild 355 short block like yours, I already have a custom built pro-systems carb to compliment everything.
Josh
It will be quicker than that. If you ran a 7.43 at 92-93mph, then it would fall right in line with an 11.50-.60. You ran 97mph which is VERY good for that ET. Assuming you get out of the hole the same, and then have a top-end charge like you did on that 1/8th pass, you'll be looking at some solid 11.3/4's.
