13 second timeslip eludes me still
Old 10-11-2010, 09:03 PM
XFiveLiter's Avatar
Default 13 second timeslip eludes me still
Car is bone stock with the exception of a res delete and Magnaflow mufflers that were replaced only because the stockers rotted out already.
Ran a slew of 14.0s and 14.1s. Best pass of the day was 14.010 @ 98.68 (2.08). Pulled the spare and trunk mat out but could do no better. Dammit!
Guess I'll have to wait for some killer air to get my desired results.
Old 10-11-2010, 09:08 PM
94ss06gxp's Avatar
hmm your 60's are pretty good, i would try a fenderwll intake or a cutout and see if you cant squeeze out a little time.
Old 10-11-2010, 09:18 PM
DavidGXP's Avatar
Run your rear tires up to max pressure and keep your fronts stock. 1/16th tank of 92-93 octane and pull out your driverside headlight. Your 60's are good enough. You'll get it don't worry.
Old 10-11-2010, 09:20 PM
2005gxp's Avatar
try letting ur car cool down longer between runs and even push ur car thru the staging lanes
Old 10-11-2010, 09:23 PM
AlabamaGuy's Avatar
Idle with the hood up (good for open element cars). Not sure about closed box designs.
You'd be surprised what a better DA will yield.
Old 10-11-2010, 09:34 PM
XFiveLiter's Avatar
Thanks for the suggestions. I had about 40 psi in the rears, should have dialed 'em up to 50. Had about a 1/4 tank of gas. Basically I didn't give it much cool down time though. Next time I will get there early and really let it cool off.
I know all about DA, used to love going when I had the Camaro and it was like 45 with a sky high barometer.
