will this pcv be acceptable
Old 10-11-2010, 11:49 PM
slap(A)hoe's Avatar
Default will this pcv be acceptable
i took and put the pvc in the back of the drivers side valve cover come off it with a hose, then i cut the hose that comes off the brake booster and put a T in the hose and ran the hose coming off the pcv valve to the T. so the brake booster is still hooked up to back of intake but the pcv pulls vaccum off the brake booster. and on the passenger side i capped off the front nipple off with a rubber cap and on the back nipple i ran another hose to a small filter i bought from advance auto and it sits in front of my fan where it can get freash air ....
so with that being said does this sound like it would work????
Old 10-11-2010, 11:59 PM
Marshessn's Avatar
I highly, highly suggest against this. Just do it right for christ sake.
