Drag Racing Tech
gain from 4.10's to 4.30's?
Old 01-31-2004, 09:59 AM
AINT SKEERED's Avatar
Default gain from 4.10's to 4.30's?
I am changing gears because of terrible gear whine. Set up right there should be little to none,mine is very loud. I am considering going to 4.30's just to see what I can run with them and was wondering what others have done with this swap? Most of my runs are on Nittos but I hook well on them so I dont think there will be a problem to much with traction . I will just readjust my launch a little. Is it worth atleast a tenth?
Old 01-31-2004, 10:11 AM
Hardtop's Avatar
It might be worth a tenth, it depends on where your car is making power. If you do most of your racing on Nittos, I would stay with 4.10's. I have 4.30's and Nittos don't even come close to hooking the car.
Bruce
Old 01-31-2004, 10:46 AM
EVIL's Avatar
Bruce
hook better than f-1's!
Old 01-31-2004, 12:07 PM
MARKSZ71's Avatar
about a tenth i loved 430s in the 98
Old 01-31-2004, 07:21 PM
It peaks at 6200 but carries its power all the way to 6700rpms. I should cross the finish line at 6700 @119 mph. SOmetimes I do run on et streets but plan to start running them more as 315 Nittos are to expensive to change that often.
