Line Lock?
Line Lock?
Can somebody tell me what all is involved in installing a line lock to lock out the brakes to the rear wheels? I'd like to be able to do some burning out without having to turn the wheels against the brakes.... Also, when burning out what else do I have to look out for?
The theory behind it is placing a solenoid between your master cylinder and your ABS modulator (front brake line only). Utilizing a mechanical switch to arm the solenoid holds pressure in your front lines to lock the front wheels. This allows the rear wheels to spin freely.
We've got a few different types that you can choose from at great price-points...directions w/schematics are included with each complete kit. Each kit contains wire, electrical connectors, a master arm switch, LED indicator (indicates when the system is armed for safety) and an activation momentary switch.
Steve
Steve
