PartsTaxi.com
10-18-2010, 04:33 PM
There has been alot of talk throughout the different forums about reducing the rotational mass of the clutch/flywheel assembly. In response, and by request, we are now offering our LS7 clutch kits 2 different ways.
Standard LS7 Clutch kit with OEM Clutch, Pressure Plate & Flywheel (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890898&siteid=215330&catalogid=6984) - $419.52
LS7 Clutch Kit w/ Ram Aluminum Flywheel and ARP Flywheel Bolts (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=892762&siteid=215330&catalogid=6984) - $599.99
Genuine GM LS7 Clutch and Pressure Plate with upgraded Ram Aluminum Flywheel and ARP Flywheel bolts. Ram Flywheel weighs 19.5 lbs, reducing rotational weight 7.4lbs over stock.
