couldnt get out of the 13s, a lil problem
Old 10-18-2010, 11:12 PM
flintwrench69's Avatar
Default couldnt get out of the 13s, a lil problem
I went to the track this past Saturday to get a few runs in. Last year cam only I was running 12.3 @113 with a not so good 60 time. This year I got my TFS 215 heads installed & the car really pulls hard. Anyway I have made a few other changes. I lowered the car with Strano springs & went back to the stock torque arm as I kept scraping with the UMI tunnel brace mount torque arm & the crossmember got damaged. Anyway for the first time I experienced some terrible wheel hop when launching the car. After only 2 runs I decided to call it a day, ran a 13.7 & a 13.2 @ 115. I ordered a MWC rear & I am just gonna wait til I get that installed before I go back, then I should be good. That should be on the way in a few weeks. With the car wheel hopping as bad as it did, I am lucky I didnt break something.
My black SS
30th TA w/ 10K on the ODO. You dont see these often. Wish it had T-tops.
Sick Monza
69 gold SS 350.
Old 10-18-2010, 11:25 PM
waterbug1999's Avatar
when u lowered it did you add the LCA relo brackets? That will put the LCA's back to the stock angle and help the wheel hop.
Old 10-18-2010, 11:47 PM
No I didnt but after reading about others with wheelhop problems I know its gotta be because I lowered it. Damn wheelhop was brutal. The MWC rear I ordered has the LCA holes predrilled in the brackets so you can adjust it. I will just wait for that before I track the car again.
Old 10-22-2010, 07:17 AM
DietCoke's Avatar
SB2 stuff is expensive :o nice monza indeed
Old 10-22-2010, 06:52 PM
1_bad_TA's Avatar
stiff lowering springs are killing you
Quick Reply: couldnt get out of the 13s, a lil problem
