Third Gen F-body
Old 10-28-2010, 10:08 PM
Rhino83's Avatar
Default Third Gen F-body
I'm putting a 6.0 truck motor in an 89 camaro will the stock truck oil pan fit????
Old 10-29-2010, 07:34 AM
camarof41_383's Avatar
The truck pan hangs too low, you will want to use a f-body pan for your swap.
Old 11-01-2010, 07:53 PM
Isolde's Avatar
you'll find all your answers on www.thirdgen.org
Old 11-02-2010, 01:27 AM
Wnts2Go10O's Avatar
https://ls1tech.com/forums/conversio...l#post13722058 not mine but in this section
Old 11-03-2010, 12:42 PM
BlueMagicSS's Avatar
The truck pan won't work. You will need the F-body oil pan along with the f-body dipstick. You will also need the front accessories from the F-body and an LS1 or LS6 intake, the truck intake and accessories won't work.
Old 11-04-2010, 02:20 PM
1A Dan's Avatar
also recommend thirdgen.org
you have to go with the fbody accessories and pan if you want things to fit. good luck with your swap
