Took car apart for paint... now interior lights wont go off
ok as it says guys i completely disasembled my car for paint and after putting the doors and rear hatch back on the interior lights still wont go off any ideas?
Save the manuals!
Either:
- Your dimmer switch is on or bad.
- The switches on the mirrors are on.
- One of the door or hatch sensors is sensing the door is open.
- Your BCM is bad. (not likely)
If your BCM is sensing an open drivers door or hatch, you'll get an indication of that when the car is on or the key is put in the ignition. Did you hook all of the latch sensors up in the doors when you re-assembled the car?
What happens if you let the car sit for a while with the doors shut? Do the lights eventually go out?
i reassembled the doors myself. i have no idea which sensors are the latch sensors but when i put them back together there were the two plugs in each door i knew one was obviously for the auto locks wasnt sure what the other one was for.. they both got re connected on each side.. ill keep digging
