Engine Brackets and Headers
What type of headers would be the best to put in and about how much cost would they be. And someone was teling me that I should replace the engine mounts with poly ones. How hard is it to change the mounts and how much are these poly ones that I should buy?
Location: Your girl's back door giving her the long stroke while you're at work
Best header depends on how much you want to spend. Motor mounts are either Energy Suspension or Prothane and I got mine for $65 shipped a couple weeks ago
are they pretty easy to install. do i need a engine crane to hold it in place while i replace them. and where did u get ur from. I'm probably gonna have like 200 to 400 for them. im getting a custom x-pipe made and am looking for the best type of electric cut offs.
your not going to get much for 400 maybe a set of pacesetters and they are a good set for the money.. I would not do the mounts they will make the whole car rattle and vibrate if anything just do one on the torque side.
People had said tho that when u have the original mounts in there it will cause the header to rattle against the frame and to avoid that u need to change the both of them out. My car has 170,100 miles on it.
