LS1 oil pressure sender output range
Old 11-01-2010, 07:11 PM
FastKat's Avatar
Default LS1 oil pressure sender output range
Does anybody know the output range or specs on the LS1 oil pressure sender / sending unit?
For instance, a lot of aftermarket gauges are 240 ohms at 0 psi, and 33 ohms at 100 psi.
Old 11-01-2010, 07:52 PM
Earl Filter's Avatar
https://ls1tech.com/forums/generatio...r-voltage.html
Does this help? It's all I found on the subject. Just trying to help, from the other guy putting an LSx/4L80E into an XJ6.
Old 11-01-2010, 08:24 PM
FastKat's Avatar
Thanks for the post. That came up on my initial search, and I don't really trust it... it seems like they're feeling around in the dark. All the gauges and senders I've come across are measured in ohms of resistance, not volts... unless LS1 sensors are different, which that post really doesn't suggest. It does suggest that the sender functions in the same direction as the gauge I'm trying to match, so that's a start.
Somewhere out there, somebody made a chart of stock (not aftermarket) sending units, and I want to see what the values are for the LS1.
I might call Street & Performance tomorrow. They're pricey, but they seem to have every specialized part you can think of for the LS1... and then some.
Old 11-01-2010, 08:45 PM
FastKat's Avatar
I did some more searching around - looks like the F-body gauge is 0-100 ohm, with 40 ohms being about 30 psi.
Old 11-02-2010, 07:21 PM
S10xGN's Avatar
FWIW, my '96 S-10 factory OP gauge is 0 - 90 ohms...
Quick Reply: LS1 oil pressure sender output range
