How much is this worth?
Old 11-05-2010, 01:05 AM
383k5's Avatar
Default How much is this worth?
I'm currently looking to buy an L92, 6.2L to replace my 383. Anyway, I've been out of it for a while and I'm not sure what to ask for my 383. Anybody have any comments or ideas about how much this could go for? Specs are listed below....
Thanks!
Speed-O-Motive 383
1 piece RMS block
Speed-O-Motive 383 crank
Speed Pro Hypereutectic Pistons (9.63 to 1 with 64cc heads)
HP Performance Heads from a 305
64 CC
194/160 Stainless Valves
3 angle valve job
Mildly Ported
Comp Extreme Energy Camshaft
Hydraulic Flat Tappet
230 int/ 236 exh @ .050
274/286 advertised durration
.487/.490 lift with 1.5:1 rocker (although I am running 1.6:1)
110 deg. lobe seperation
Brand New Holley 750 Double Pumper w/ Pro Form center section
35 Power Valve
Stock Accelerator Pumps and Cams
Extended Front Fuel Bowl
Spring Loaded Needles
Jet extensions and notched float in rear bowl
Edelbrock RPM Airgap Manifold
Mallory HEI Billet Distributor with vacuum advance lockout
MSD 8.5mm Spark Plug Wires
Comp Cam roller tip 1.6:1 rockers
apx. 15k miles
currently in car and you can hear it run
have all receipts
