Autometer wideband a/f ratio install.
Installing autometer wide band a/f ratio meter. Anyone know wiring procedure
for 2000 WS-6. specifically the brown wire option that requires a monentary
closed wide open throttle switch. and the blue/black, blue wires which are wired to the data logger output (engine managment, data aquisition unit)?
I assume the switch has to be installed off the throttle? were do I
locate this switch Thank You "Last of the Breed"
ANY ONE KNOW BENEFIT OF MOUNTING A WOT SWITCH OFF THROTTLE AS
OPPOSED TO GROUNDING CONSTANT. HAS ANYONE PERFORMED THIS??
