HOW to wire in DDM 55W lows and 35W fogs with harnesses TOTALLY LOST!
I will be spending my evening trying to find out how to wire up my HID's. I have NO idea where to begin.
I got the 6000K 55W lows with harness.
Also got 5000K 35W fogs with harness.
I've been reading post after post about using the LMC housing. Okay good enough, but HOW do you wire in the rest of the harness, I have no idea where to begin, what goes where, what plugs into what?
I have a feeling I bit off more than I can chew with this project.
not hard at all . you just need a test light to get "turn on" and ground. basically you just wiring it up accordingly and make sure you tape them up and the connections arent loose and you should be good along wit the ballast ,make sure there not moving around and thats it.
It might not be hard at all, but sure as hell ain't easy. I guess I should of requested detailed step by step pictures. Until then or I find somebody thats close by to do it, ***** going back in the boxes.
