90mm throttle body on BBK Question
Trying to figure out if anyone has done this or if it can be done eddlebrock has a 3 bolt 90mm throttle body and the mouth of the bbk intake is is 3 5/8 inch with equals 92 mm so will it work.
Is it the Edelbrock #350-3864 you're looking at?
The only thing I noticed is that there's no air tube/pcv hose hook up on the passenger side of the TB.
Wilson Manifolds #474090 looks like it would work also, plus it has the hose hook up on the passenger side of the TB.
The down side is that it cost over $100 more.
throttle body
Re measured the opening with my caliper and it come to 88.9000mm pretty sure you can get 1.1 mm with a little massaging.Wish i had one to try to see how far it was off.And yes i was looking at the Edelbrock throttle body
