408/giant cam questions.
anyone running a 408 with the TSP giant cam?
i plan to use my prc 5.3L stage 2.5 heads.
my questions are. what -cc valve relief should i go in the pistons?
and also. are you using stock length pushrods? (7.400)
havent ordered my rotating assembly yet. just want to make sure my ducks are in a row before i do.
i plan to rebuild the heads and use a 6.750 rated spring (that TSP offfers). and change the valves out with manley pro-flos.
I had Texas Speed install my 408 stroker with their texas giant cam and used their PRC 5.3 stage 2.5 heads. Anything about internals you would have to ask them directly I lost the install/receipt sheet. It has been over a year and a half ago and it is still running strong. I think I have a video of my car somewhere.......
http://www.youtube.com/watch?v=8V12v4bUEZg
LS1Tech Premium Sponsor
The Wiseco -8cc dished pistons, GM MLS gaskets, and those heads will net you about 11.5:1 static compression which will still be pump gas friendly with that cam, and will help maximize the combo and keep low end and mid-range throttle response (torque) healthy!
Pushrod length will need to be measured after the rest of the long-block is assembled.
Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
