LS6 cam.. spring settings
Old 11-17-2010, 06:29 AM
LTZCory's Avatar
Default LS6 cam.. spring settings
i am doing an ls6 cam in a 5.3L with 317 heads. i am looking for the correct info to tell my engine builder to set my valve springs? does anybody out ther have any input?
Old 11-17-2010, 06:34 AM
crainholio's Avatar
You need an engine builder who knows what he's doing.
Old 11-17-2010, 06:46 AM
LTZCory's Avatar
i am just having him freshen my heads up and put my manley springs in. engine builder has no info on the ls6 cam? local (machine shop) just need to know what to set these at?
Old 11-17-2010, 08:55 AM
TurboBuick6's Avatar
I would think between 120lbs and 140lbs installed should do you good.
Old 11-17-2010, 09:26 AM
Jon@Texas-Speed's Avatar
What springs are you trying to run? Just throw in a set of PAC 1218 springs and be done with it. If you are trying to install LS6 springs and shim them or something to get your seat pressure, it would be easier and probably safer to just replace.
Jon
