Security system issue
Old 11-19-2010, 12:20 PM
BLUEBYU's Avatar
Default Security system issue
The security light is staying on and not allowing a startup, but then after a few tries it goes off and starts. I have the VATS system set to "None" instead of "PWM". Would that cause this problem? Thanks for any help.
Old 11-19-2010, 01:56 PM
2001NBMZ28's Avatar
The other portion of VATS is in the BCM which enables the crank circuit to the starter. It also sends a signal to the PCM fuel enable circuit. Bypass VATS with a resistor matching the key and you should be OK.
