trans crossmember 79 camaro?
Old 11-22-2010, 11:44 AM
brad22486's Avatar
Default trans crossmember 79 camaro?
need to find a transmission crossmember for ls1 auto into 79 camaro im using the transdapt motor mounts? any help would be appreciated. thanks
Old 11-22-2010, 04:46 PM
eroc022's Avatar
i took my original one, cut the mount off it, and rewelded it to it. but a few companies make some, i know bowtieoverdrives.com carries one, and then a complete bolt in one is made by crossmembers.com which is what im thinking about going to, as i believe it will give me the room for my exhaust...
Old 11-22-2010, 06:07 PM
JIMB's Avatar
I used the stock 79 cross member. Just moved it back and drilled new holes in the sub frame.
