LS1 Info Section
LS1 Info Section
I have an idea. Since LS1 Info is now defunct, and because they did have some really good reference material; what if LS1 Tech were to add a forum on this site where you could go and look up reference material for research purposes? It follows the premise of "one stop shopping", and would just bring more people to the site and enhance the sponsors end of it. It would be kinda' like the conversion tables and formulas that manufacturers put in the back of their catalogs.When you look up the info, you just happen to remember that you needed somethinh else, and bam you buy from them. It woud be a virtual reference section only; not something that people could respond back to. Material such as oil passage flow; firing order, block material, rod weights, bearing material, compression ratio, fuel injector flow rate, trouble service bulletins, etc., basically the whole gamut. This way you could have the info without it taking up extra bandwidth from someone posting the same old questions or from people doing searches. It woud really enhance the site even more. I don't know if there would be a way to get the info from the LS1 info site, but if you could contact the owner, maybe you could get that software.
