Just installed FTRA and Moved tranny cooler
Only i can make something so simple so hard. The tranny cooler was the problem.I thought for sure it would fit beside the ftra longways.It wouldnt because the way the line ran into the cooler. Anyway after i got the cooler out of the way it was easy. I ended up mounting the cooler up behind the Pass. side foglight.It leans back and is zip tied to the horn. There is vents on the bottom side of the pannel and you can see the cooler through there so i think it will be OK. Its snowing out so i cant take it for a drive yet
