DBW help
DBW help
I have found a 02 silverado that was totaled my question is the gas pedal conections to the tac module.Is this a pigtail from pedal to tac or is it pedal to wiring harness inside the cab?Thaks for any help,Mark
If it's a 2002, then the harness between the pedal and TAC is combined with another harness, not sure if it's a body harness or the engine harness but it's not seperate like 2003 on up. Is this really a Silverado, or is it a Surburban? I've never seen a DBW truck in 2002, but have seen Suburbans and Yukons that were DBW as early as 2001. That said, I'm reasonably sure that you can use a jumper harness from a 2003 to 2005.
the truck came up at auction here locally and I have not seen it up close yet just the posting on the internet site.The auction is friday and all i need is a gas pedal and tac but thought that the whole truck would be good to have if i could get it cheap enough.
Some of the early DBW harness are included in the body harness including some 2003's I have seen. The later pigtail harness should work with the 2002 pedal and TAC. Just find one of those off a newer one.
Also, some 6.0L and 5.3L in 2002 had DBW mostly the caddy stuff and GMC C3 etc...
