"pre lube"?
"pre lube"?
i just picked up an lq9. took it down to the block, cleaned a lot, reassembled. i also changed the cam. its a used torquer 2 out of my ls1. 3 questions:
will the cam need to be broken in?
i knwo when i did the swap on my ls1, i had to coat the cam in oil. i did this again, but its been sitting for a week. do i need to do anything before i start it to get oil on everything?
anything else i should do prior to turning the key once its in and put back together?
