EPS 226/230 116+1, Grind 13117R/13118R
226/230 .598/.600 116+1 on EPS lobes. Grind 13117R/13118R
Need better info on this cam quickly .... for a stock LS1 with stock ls6 intake & planning to get a direct port wet NOS .... anybody running this cam or maybe Geoff & Patrick G could through in a few details on this grind.
Estimated Power range N/A ??
Cam response with 100 wet shot ??
Power Band Range ??
DD Manners ??
Thank you all for your input in Advance !!!
Power Band Range ??
DD Manners ??
This is a pretty bad cam for only a 100 shot i would lower the LSA to at least a 114. to be more specific i would do 226 230 112+2. Cam has 4 degrees of overlap at .050. Your DCR will be good with this cam so you will make more power with that 100 shot. If you were blowing like a 250 or something yea you would need a different cam, but you can spec this thing like its on motor esp with a cam this small.
thought so too about the 317 heads .... i gave Geoff an email asking him about off the shelf cam listed on their website & will run this over again to him.
