smog and other bullshit
i am rebuilding motor and plan on running headers. what do i do to get rid of the smog equipment and have it run right? i assume that will be taken care of in the tune i will get after break in?
remove the AIR pump (low drivers side of the motor) and EGR valve (back of intake) and block off the two holes left open. You can also remove all the associated tubing with both systems.
removing both shouldnt greatly affect the performance of the motor... but since you're getting it tuned anyway, have both tuned out.
do you know who sells them or is there another way i can block them off?
