Reverse idler washers.
Old 12-15-2010, 11:12 AM
sssalah's Avatar
Default Reverse idler washers.
The manual shows 2 washers for the reverse idler gear, but I have non. This trans seams to have been rebuilt before and whoever did it forgot to put them back in. The idler gear has some movment, and I'm not sure where I can get these washers and whats their thickness.
Thanks for the help.
Old 12-15-2010, 11:39 AM
jmd
jmd's Avatar
How much movement? The washers are fairly thick and they were different, depending on year(? someone else who has built more wanna chime in?)
Old 12-15-2010, 01:19 PM
85MikeTPI's Avatar
There may be 0, 1, or 2 washers depending on the gear, tailhousing, and plate. If the play is less than a washer-thickness, it won't be a problem.
Old 12-15-2010, 02:55 PM
sssalah's Avatar
What's the thickness of the washer? I'm having around 0.02" of play.
Old 12-15-2010, 03:27 PM
85MikeTPI's Avatar
I don't have one in front of me, but they are about 0.125" thick.
Old 12-15-2010, 03:37 PM
jmd
jmd's Avatar
Some boxes had none. You have 20 thousandths, you're good.
Old 12-15-2010, 11:56 PM
sssalah's Avatar
Thanks guys for the valuable help.
Quick Reply: Reverse idler washers.
