bad mass airflow sensor?
Old 12-22-2010, 03:34 PM
minnesnowtaz28's Avatar
Question bad mass airflow sensor?
i'm looking at replacing my MAF with a bigger one and in Jegs i found Granatelli and Jet both have them for around $300. Then there is one made by Venom for $120. I can't seem to find any info or reviews about it. Does anyone actually have one or know of someone who does? Is it a great deal or just a piece of ****?
Old 12-22-2010, 03:39 PM
quik95lt1's Avatar
just out of curiousity what is done to the car you are putting it on???
Old 12-22-2010, 03:44 PM
i just recently bought it and it already had CAI, 3" exhaust, 3.73 gears, and i believe the ECM may have been tampered with cause the shift points seem a little high and the spedometer has been corrected to the gears
Old 12-22-2010, 04:19 PM
Fazz73jr's Avatar
Spend the money elsewhere... longtubes, RR's, cam...
Old 12-22-2010, 04:24 PM
defaultexistence's Avatar
dont waste the money, bigger MAF needs a tune , you aren't out flowing a stocker ......Dx3
RamAir95TA's Avatar
There is ZERO benefit to running a larger MAF. Not to mention aftermarket MAFs can be a tuner's NIGHTMARE. They are often more trouble than they are worth.
The stock MAF can support BIG power. And even if you're to the point where the MAF is a restriction, you might as well convert to speed density.
Yea my plan is to get some Pacesetter lt's within the next couple months. I'm trying to get all my bolt-on **** done within the next year then I'm deploying to Afghanistan and when I get back I'm planning on doing a full rebuild of the car. I also wasn't aware it would need a tune, I'm pretty new to these LT1 engines. I appreciate the warnings lol
Old 12-22-2010, 07:02 PM
MattSapp95_T/A's Avatar
Exactly! no reason for a aftermarket MAF EVER!!
Old 12-23-2010, 07:44 AM
quik95lt1's Avatar
yep listen to these guys above.......the stock MAF will support over 500 hp.........spend the money on something better.......
Old 12-23-2010, 07:51 AM
mguidry629's Avatar
^^^^ agreed!!!!!!!
Old 12-23-2010, 09:06 AM
SS MPSTR's Avatar
OP, if yours is bad, I have a couple stock ones. PM me if interested.
Quick Reply: bad mass airflow sensor?
