Got another miss
Old 12-24-2010, 01:18 PM
lethal bird's Avatar
Default Got another miss
Ok so I was driving my car yesterday and it was driving ok and all of a sudden it started to miss. It has a miss through any type of load and set the idle down to like 600. I had to replace the o2 sensors and I bought two used ones off of here for little to nothing, I knew i was going to need one extension so I got one along with the two sensors. Got one installed and then found I needed another one so I drove it with the one new one and the one old one and it drove fine. I finally got the other extension and put it on. It drove perfect for about a day or two and now it will miss with any type of load. Im pretty sure its the o2 sensor but wanted to check what you guys thought before I went ahead and bought a new one.
Old 12-24-2010, 01:42 PM
SoxXpupPeT's Avatar
check your spark plug wires aswell. all you need is one to be alittle burnt and your done
Old 12-24-2010, 01:44 PM
Already did no burnt wires.
Old 12-24-2010, 04:40 PM
That and it only does it when it gets to opporating temp.
Old 12-24-2010, 06:33 PM
Ok so i pulled the o2 and cleaned it with sime brake cleaner and no change. Then i unpluged the maf and it drove fine but still had a smallllll mis. What does this mean?
Old 12-24-2010, 06:39 PM
MattSapp95_T/A's Avatar
Coil? i know they act worse when they get hot...
last time my car did that it was an opti issue...
Old 12-24-2010, 07:03 PM
shocka4's Avatar
I had the same problem and I had it checked out and they told me I had 4 fuel injectors going bad and they didnt start acting up until the engine was warmed up it could easily be anything I would start with checking the easy things first but that was my experience w my 94 formula.
Old 12-24-2010, 07:17 PM
So why does it clean up and quit missing when the maf is unpluged.
Old 12-24-2010, 07:26 PM
I have a Maf if you wanna get one
Old 12-24-2010, 11:38 PM
RamAir95TA's Avatar
Trying to clean O2s won't really do you any good....FYI.
Quick Reply: Got another miss
