Brand New ls7 Lifter Will Not Fit In Bore
Yes it can be one defective lifter, but I think that is pretty rare. If you have not tried it all ready, you might pull all the lifters and see if that particular lifter will fit any of the holes. It would still need to move in and out easily - you do not want to force it in any event.
My thought is that perhaps the lifter is just at the upper end of the tolerance range that you might have one hole that is also a little larger than the others.
Also make sure the lifter does not have any kind of a burr or knick on it.
