what bolt pattern is a l98 crank flange
im woundering if the L98 Australian 6 lt crank to flywheel flange is 6 bolt
or 8 bolt like the ls3
and lsx 454
thanks
and lsx 454
thanks
ill answer my own question as have found the answer
LSX 454 crate engine uses an 8 bolt crank.
Pre 2009 LS series use 6 bolt. 2009 and up LS, LSA and LSX use 8 bolt. LS9 crank uses a 9 bolt flywheel.
