5 volt relay
5 volt relay
Anyone know where to find a 5 volt relays? I'm converting a returnless system with fuel pump control module, to a return style. I need to run a 5 volt relay of ECM fuel pump turn on to energize Racetronic relays. The fuel pump turn on circuit, out of ecm, is a low voltage turn on input to FPCM. I'm cutting that circuit and using a low voltage relay to energize fuel pump relays.
