valve spring ?
valve spring ?
can i run patriot extreme dual springs 660lift on a 580 lift cam? will they cause more wear on my valve train than a lower rated set of springs? or should i go with a 600lift beehive single spring setup?
You can use the. Depending on how many rev's you want to hit you may need to shim them to get closer to coil bind at max lift. This however may raise seat pressure too much. If you have em use em, if not I would go with a beehive.
