i need some help with my centerforce disc :(
So i pulled my motor out and had to pull the clutch off to put it on the motor stand (thank god) and found this today when i pulled the disc out
clutch has maybe 7500 miles on it, everything looks good minus the missing puck.
anyone had this happen before? or know if the centerforce warrentyl policy will cover/replace it?
Good luck getting them to replace it unless your still under their 90 day warranty. Any noises with it? I wonder where it went. Check out my thread, I have the same clutch but a different issue:
http://forums.corvetteforum.com/c5-t...m-failure.html
**** really?
there was a TON of dust in the bellhouse/pp/disc assembly so maybe it just grenaded? IDK i was having no problems with the clutch at all! The motor came apart on a 7K rpm granny shift. I havent beat on this clutch more than 4 or 5 1/8 mile pulls and a few 1-4WOT runs
**** really?
def will do billy. was def not hoping to have to spend more $$ cuz i dont have it after buying parts to rebuild the motor lol. It came apart on me the day after i picked it up from you guys
