Pontiac GTO 2004-2006 The Modern Goat
lingenfelter fuel pump?
Old 01-06-2011, 06:10 PM
LTZCory's Avatar
Default lingenfelter fuel pump?
looking to upgrade my fuel pump and been doing some research. Lingenfelter seems to be the only company that offers a low cost fuel pump kit for the 04-06 GTO. my question is will it support my turbo gto running somewhere between 600-700 rwhp @ 15psi. if need be i was planning on adding the kenny belle boost-a-pump? is that necessary?
Old 01-07-2011, 12:08 PM
05TurboCGM's Avatar
The Lingenfelter pump is nothing more than a Walbro and they use their own special adapter that comes in handy when installing.
At that power level, you will not be able to sustain proper fuel pressure with the LPE pump and a BAP. You'll need to look into a dual pump set up with a full return.
Old 01-07-2011, 07:42 PM
LTZCory's Avatar
does anybody offer a dual pump set up for the gto?.... if i buy 2 pump kits could i make that work?
Old 01-07-2011, 08:56 PM
06blackGTO's Avatar
I run the lingenfelter/walbro setup. And at 540rwhp. Im running out of fuel on the big end.
Old 01-10-2011, 03:36 PM
oldstv's Avatar
Default fuel system
Contact Lonnie he can hook you up on the complete package. I just got one and am doing the install now. You just need to look for Lonnie's performance on the board.
Quick Reply: lingenfelter fuel pump?
